B
Blinky
My 440 just quit yesterday AM after running long enough to make a small undercut. Acted like idle was set too low and puttered out, wouldn't restart even after I reset the mixture screws to factory.
Last time I had trouble with this saw it was the fuel tank vent getting clogged so I checked that, took the carb off and checked the bottom screen, all clean, put the carb back on. It started but revved way up until I killed it. Did that a few times until I found the idle screw was in too far.
I'd noticed the carb accumulating raw fuel outside the throttle butterfly before taking the carb off but figured it was related to the idle being way off. I reset the idle and it hasn't started since but it's filling the intake was fuel every time I crank it.
The mixture was tweaked, I have a Max Flow filter on it and sprung for a tach a while back, but it wasn't far off the factory 1/4L and 3/4H.
Last time I used it was a week ago and it was slinging chips like crazy.
