Wood stove heat
  • Views Views 141K
Yoooo. Question here. Now that I'm retreaded, I'm burning a lot of wood everyday. And I'm happy to report btw that my wood supply is working out quite well I think bc I made sure to cut all pieces reasonably short to help with the 100% hand splitting and I split all pieces a lot as in no big chunks. Those 2 factors I believe facilitated faster drying in my large stacked pile covered only on top with one sheet of clear plastic.
The problem I'm having is with coals. When I load up the empty firebox in the morning I get great heat out of the resulting roaring fire. Eventually of course, the logs burn down and the heat output lowers some and I then add more logs and the output rises again. Rinse and repeat. But after about 5 hours of this, eventually the level of red hot coals builds up quite high in the fire box thus physically limiting the amount of room available to add in more logs so therefore I get a reduction in heat output despite the box containing a large amount of coals.
No doubt you wood stove savants have some answers... :popcorn:
More air. Let the coals roll for a good forty minutes before adding logage.
A mix of hardwoods- red oak, red maple, norway maple, sugar maple, black locust, beech, hickory ( no fun to split lol), black birch.
Not sure if you can see this if you’re not registered
That was interesting, thx for posting! Lol when I started skimming there OP I was like, 'omg this guy is having the exact same problem as me!' :lol: :/:
I don't have any soft wood to throw in, but Imma keep thinking on it
It’s like that thread on the logger site where they stole my post about Humboldts.
FHC is a great group of guys, I should hang out there more.
I was thinking the same thing.
There was a post about using a tire on a round when handsplitting, which I do, and one guy mentioned screwing the tire to the round which makes alot of sense and I'll probably do.
I like the chain and bungee
Adapts to different size rounds
I split big stuff so I just peel away
If I wrapped it, the split pieces would be in the way of further splitting
chain and bungee sounds like a fair amount of set up time?
Simple method. I'm not sure I've ever seen the need for tire or chain/bungee :), but aside from that, seems a reasonable trick.
I did it a little on smaller wood. Pretty efficient. Keeps the mess together, throw it in the wheelbarrow or whatever, take the bungee off.
I do something similar when I split on the press. I split the round 99% apart and shove it off into a crate where it falls apart. No chasing stuff around.
Doesn't the bungee get cut fairly easily/often? The tire takes a beating without issue
You may have a bad design of stove, depending on what "full" of coals is to you. I get some of the best heat when mine is full of coals. What I don't like is w thorough mix of ash and smaller coals, which is immadiately solved by either scooping it out, or frequently stirring the ash while the air is wide open. Sometimes I put in a small piece to keep heat output up while stirring the ashes every few minutes. It is proactively solved by pushing the ash back and raking the coals into a mound around the air inlet each time you go to put in more wood, or let them burn down like that before putting more wood in if there's a lot.
The problem is newer stoves don't have lower air inlets, or they totally seal off in an attempt to burn the wood gas only, so all you end up with is coals and little ash. My dad had 2 different models of a newer stove, and both seemed to have poor performance in many ways. The EPA wants your fire to burn hot and clean, they don't care so much about how well it heats your house.
I ran into a similar problem: lots of coals, not as much heat. The problem is how I load it. I normally put the logs in sideways, like you would in any classic fireplace, and pack them in this way for a long burn and to have lots of buried coals left by morning. The wood gas still easily burns hot, but the coals quickly get buried under ash.
The other way I load is for shorter hotter burns, where I load the wood straight in, parallel with the sides of the stove, and even propped up on a sideways piece and/or propped up on the firebricks in the back. This lets the wood get much better air flow, and keeps them raised off the ash, so ash can fall off instead of smothering the coals, so the coals burn while the wood gas burns.
I've been meaning to post to this thread regarding a holiday season gift "to the house" from my lady M. A fireplace bellows for use with freshening up the fire in the woodstove, either starting from scratch or adding fuelwood to a fire that has died down to small coals.
I have to say I was under-enthusiastic about it; never felt the need for one in nearly 50 years of heating with wood. But I am a convert...it makes it much faster/easier to renew or start a fire. She got it at the Ace Hardware in town, and not very pricey. I recommend one, and I wouldn't have thought I would before using it a bit.
This one may not be the best available, some reviews are poor. But the hand bellows idea itself I am fully in on. So far, it's working fine, but we've only been using it a couple of months, and not heavily.
I have found the straight in log method to work well also. Also found when running the stove hot ash burns down more and coals burn up. Not even a lot more air, just with more wood. I usually don't burn too hot, but with cold plunges we have had the fire has been getting packed with more wood and a little more air.
The straight in log method must require a stove that is quite deep. With my Hearthstone, it is fine with 18 inch wood sideways, but it would have to be no longer than 12 inches or even less to go in straight on.
No way am I going to be cutting firewood at 10-12 inches. That's just silly :).
