Timberline saw sharpener
  • Replies Replies 78
  • Views Views 11K
Only if it was heavily dulled by rocks.
For just a touch up, it's relatively quick.
I have a 44" bar on the 3120xp, full comp but not chisel chain.
I'll try some Butch. No one sells it locally so I'll have to remember to order some. That's the tricky part.
Maggies dad ended up loaning me his timberline. I tried it today for the first time. I was hoping for pure awesomeness. I struggled with it for 15 min before giving up. Getting it set in the right spot seemed impossible. I'd get it aligned for one tooth but then it would be all off for the next tooth. There is the top thumb screw that sets the stopper. This was always way out of wack for each new tooth because guess what- on a well used chain, all the cutters aren't the exact size.
After 15 minutes I had 4 teeth done. That's when I gave up and just used a file.
I'm gonna have at her again NOT on the jobsite and even though I was watching the how-to vid while doing it, I think I need to watch it 5 times to see if there are little things I'm missing. But so far, not impressed.
love
nick
Well Williard, I've got to say that you and Willie (SOTC), and John Emmons, (Highly respected Old-Timer at our shop), can't all be wrong. I remember the first time that John got a good and deep belly-laugh at the sight of me butchering up a good round-ground chain to "convert" it over to my double-bevel file. "That edge will never stand up to residential work, Jed," he said. Ah, well, all you guys can't be wrong, except that John takes the whole issue one step further, and insists on the Semi-chisel stuff. :( "Keeps it's edge way longer," he insists.
Ah, who knows... they're probably right. ................ All I know is, competitive fellow that I am, (God forgive me), I'll bury my tired as heck little 440 with a full-skip square grind, 28", and beat any of them boys. :P
I trust you about the comp saws though. Stands to reason: if you've got the power to shovel the chips, then cut more off, and the job goes faster. Still... I never really understood the argument about sharpening time. True, I have to take the gullets out with the round file, but, outside of that, if you use the triangle (hexagonal file), and you just barely graze the tie-straps, with a 30 degree downward stroke from the front, you can keep consistent angles, AND finish the chain just as fast. The goof file is even faster. Faster, I swear than even a round file, and if I could post vids, I cld proove it. To bad that you and Tucker would be the only souls on this green earth that would watch it!
