Mt. Dewey trail.
  • Thread starter Thread starter stikine
  • Replies Replies 22
  • Views Views 2K
Amazing the amount of gravel use for a foot trail
  • #11
Yeah, not cheap but the hope is that there is much less maintenance than the boardwalk style in the future. This trail is on city property and will get used a lot by cruise visitors. The first section through the muskeg was originally designed to be narrower but the bids came in too high because they couldn't use some larger equipment. The City modified the specs and the bids came within budget then.
Do you know how long, and how much money? My trail is $7m if I remember right, and 8,500'. Just curious. The conditions are so different between them, there isn't really a direct comparison.
  • #13
I could toss out a price etc. but it would probably be wrong. I can get it from my contacts though and then report back.
The drain?
The valley floor is mostly made of dirt that used to be the Grand Canyon. It’s flat and irrigated by concrete canals. They run into the fields which drain into dirt canals aka ditches locally called drains that all drain into the New River and eventually the salton sea. The red was on fire, we were approx blue. You can see the raised dirt lot with hay stacks on it behind my truck.
