Robert P
- Joined
- Jul 11, 2014
- Messages
- 275
I had my Echo saw apart, the worm gear was fine, looks as good as the new ones I ordered along with new oiler pumps anticipating I might need to replace them. The oiler pump gear turns easily with a screwdriver tip. Checked the oil pickup in the reservoir which looks fine, shot some parts cleaner into the outlet hole by the bar attachment, put it all back together, filled the oil, fired up the saw without the bar - the oil doesn't come spraying out, it comes out at what I'd call a solid ooze which increases as the saw speed increases - is that about what it's supposed to be?
