thattreeguy
Ok , so we all know i bought a sweet aloc, and i was having a blast with it.
I rebuilt the pto, (the dealer did but it went out again) so i had it done, and it had a cracked shaft, my guy fixed it and its now a non issue, i paid for it myself.
so i noticed some issues with the hoses not laying right , and then the boom wasnt quite leveling right, then the weird screech sound and a lil wobbling at the turn table.
So i took it to Altec and did the 8 hour inspection.
They found the hoses were routed improperly and were being damaged, also the improper routing damaged the leveling system, but it is adjustable, although the unit needs to be rehosed.
Turntable bearing is a fuzz away from being toast, and needs to be replaced,
and the dealer painted the boom with the truck, well they didnt gel coat the boom, and with all the old scuffs in it they say it needs to be stripped down and gel coated.
and the lower lock valve is leaking and needs replacement
total repairs is over 11 thousand dollars, when its done it will be fresh and pass its certs
currently not operable...well it is if you want to risk it.
so i called the dealer and tore into the sales guy...he says he will talk to the owner and we will talk monday.......
what would you all do.....i was thinking 1/2 qnd 1/2 or i get the turntable, they get the rest.........keep in mind ive had it about 6 months...and its a "reconditioned unit" with both certs supposedly current..
whats fair here guys
and mb feel free to move it to elders if you think it would be better there.
looking forward to your thoughts
