SkwerI
Without looking, I'd say that he made the snipe cut in order to allow the falling tree to continue in a straight path with less liklihood of being forced to twist or kick off to one side.
:what:Here's an idea from an utter newbie, so take if for what it's worth.
First, make your flat cut using the saw sights. then stick a strip of cardboard (6" wide, by 3' long or so) in the cut, all the way to the back so that it sticks out on the far side. This is going to be a "sight aid".
Following Burnham's recommendation, line up and dog in on the near side, and then sight the tip of the bar to line up with the edge of the cardboard which is sticking out on the far side of the tree. Now when you swing the saw through, your cuts should line up perfectly on the far side.
I wish I had a saw and a tree to try this. Anyone game?
I may try doing my angled cut first, when I was learning the conventional I would do the angle first then the flat. Now its a pain in the arse to do it that way cause the piece of wood ends up sitting on the bar when the cuts finished.
To make a flat butt cut, important on the big logs for millage.
You cut a humboldt and you cheat on your step and keep it small and you end up with a flush flat but which doesn't need to have a snipe cut off of it
Seems like it is a very important cut for keeping a tree on a steep hill. Wouldn't a conventional cut provide a "ramp" to send the tree over the stump? Burnham, Jerry?
Dave
Yes, it can in deed do that, but not everytime.Seems like it is a very important cut for keeping a tree on a steep hill. Wouldn't a conventional cut provide a "ramp" to send the tree over the stump? Burnham, Jerry?
Dave
Dave
