I have a bit of a battery cable obsession, which, as obsessions go, isn't the worst thing. I feel that there should only be one style of battery, the 31S, just in five different sizes. ATV, lawn and garden, automotive, truck, and large earthmover.:lol:
I have been converting everything I own to 31S, which is the stud type large truck style. I'm done with post and clamp type connections. Studs also give you a good place to add jumper cable wires, which I am also adding to most of my sawmill equipment via Anderson connectors. The alarming part is the cost of good wire.
I got some new shrink tubing in the mail today, which is a new product for me. It's a 3:1 shrink ratio, adhesive lined tubing. 4' each of red and black was like $9. You can see the finished product on the end of the cable I started making tonight. Pretty cool, if you are obsessed like me. :/:
I need to find a bigger box to keep all my parts in. I gathered everything together this evening, and there is quite the pile of stuff, at least more than I realized anyway.
How do you like the crimper? I just bought some 31s batteries. Need to make some cables or order some. Does it go up to 2/0?
The crimper does 1/8" cable up to 600 mcm, so definitely does 2/0. Temco is apparently the legit brand for these things, but the Amazon ones are half the money, and work just fine. You coukd probably find a 6 or 8 ton for $50 to $70 that would work well. Mine is a 16 ton, and overkill for my needs.
