Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 73
Thread: New Engine for splitter
  1. #51
    Treehouser Cobleskill's Avatar
    Join Date
    Dec 2006
    Western New York near Lake Ontario
    Age
    61
    Posts
    3,500
    Default
    Pretty common item at the fleas. Bought several replacements for broken ones. But Amazon is OK too. Flea markets can be fun. I bought 3 pairs of old, good shape American made pliers for $5 this fall. Bough a bunch of differnent kinds. Bargains are easy to find and fun to look. Usually a tool guy with nothing but. Try them lately?
  2. #52
    Call me Bob BlackSmith's Avatar
    Join Date
    Mar 2005
    Upnya WV
    Posts
    4,487
    Default
    Click image for larger version.
    fb4e568623b5f8cf7e932e6ba7eddc0db9f42a712718f488bd c0bf880dd3
  3. #53
    California Hillbilly Sponsor CurSedVoyce's Avatar
    Join Date
    Jun 2008
    Near Yosemite in CA USA
    Age
    56
    Posts
    38,263
    Default
    Yup, those.
    Interesting how a limited gene pool and a limited labor force seem to be so closely related.
  4. #54
    Join Date
    Dec 2006
    Age
    61
    Posts
    3,500
    Default
    I think I would drill a hole in a piece of scrap and see how that worked out before I ran it in to a brand new engine block. It might work fine, might gall the shit out of them. Aluminum can gall without much effort.
  5. #55
    Treehouser Sponsor No_Bivy's Avatar
    Join Date
    Sep 2006
    Age
    47
    Posts
    18,640
    Default
    . Already a holes in the mounting plate. The are self threading bolts not screws......no center punch needed. The bolts are three sided so to speak.
    anyway.....several you tubes of folks using and impact driver to rattle them in....I was planning on by hand slowly.
    they look similar to what blacksmith posted.........so any tips to putting them in? or just shut up and do it......
    motor here on the 5th
    a society grows great when old men plant trees whose shade they know they shall never sit in
  6. #56
    Rodent Aviator Sponsor Skwerl2's Avatar
    Join Date
    May 2017
    central Florida
    Age
    52
    Posts
    1,054
    Default
    Run them in by hand and back them up a quarter turn whenever you get too much resistance. Spray some silicone lube in the hole before starting and add more if needed while running the bolts in. They are cutting threads so run it in like you would a tap.
    -Brian
  7. #57
    Join Date
    Sep 2006
    Age
    47
    Posts
    18,640
    Default
    good suggestions
  8. #58
    Join Date
    Mar 2005
    Upnya WV
    Posts
    4,487
    Default
    In a pinch I’ve made a tap out of a spare bolt. Angle grinder and cutoff wheel or hacksaw, cut some grooves in the bolt. Temp tap, harder the bolt the longer it’ll last. Save a trip to town.
  9. #59
    Treehouser Sponsor SeanKroll's Avatar
    Join Date
    Oct 2016
    Olympia, WA
    Posts
    2,807
    Default
    Quote Originally Posted by Skwerl2 View Post
    Can you expand on this?
    If it looks like I asked a question, but put a period, it's probably a question.
    Don't know why I'm question-mark challenged online. 😀 New Year's Resolution, better proof reading.
  10. #60
    Treehouser Sponsor Tree09's Avatar
    Join Date
    Feb 2017
    Peoria il
    Age
    35
    Posts
    1,005
    Default
    You take a cutoff wheel, and manually score out the thread so it looks like a tap. You leave the following edge (the side that is going to do the cutting) either straight up and down or just slightly undercut, so it cuts nicely. You then heat the bolt up to red heat at a minimum, then quench it (works best with the higher grade bolts), ideally with some oil, lacking that, water works too but can possibly crack the bolt. You then have a redneck tap. Works with pipe thread too, but only to clean out or straighten messed up threads.
    The reason you use the higher grade bolt you can find is because of the carbon content. The more carbon, the harder you can get it. By heating it up, you are changing the grain structure of the steel, quenching freezes that grain structure. You are actually forming martensite if you have something with a higher carbon content than mild steel.
    Kyle
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
