Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 81
Thread: "Gehl Wars" Articulating Loaders
  1. #61
    TreeHouse Administrator MasterBlaster's Avatar
    Join Date
    Mar 2005
    Louisiana!
    Age
    61
    Posts
    8,676
    Default
    It's quite the unique design!
  2. #62
    Just slice it Sponsor tntree's Avatar
    Join Date
    Jan 2006
    Mpls, Minnesota
    Age
    63
    Posts
    1,309
    Smile
    Good eye Brian on the seat on/over the engine, the Finns and Italians seat swings outside of the turning Radius.
    The Norcar and the American Gehl AL 140 you sit over the engine, gets you in tighter places.
    ED, that little 755 machine is a beaut! only ~ 1800#s! Tipping 1100#s !
    Do you know what that little guy costs? What is the comparable Avants cost
    The Euros got the shit when it comes to the baby articulting machines.
    The coolest Mini mini arty in America is the stand on Ditchwitch Zahn.
    Not a sit down but under 36" wide, optional Duals -
    I would be hard pressed to buy any mini skid over the Zahn if I was to get back into day today Production again,
    think I would go with Norcar though if I could get my hands on one of those better lift and my lazy ole butt can sit down
    CARL help !!! Can you translate metric speak, I mean specs
  3. #63
    Wolfish. Sometimes Bites. Sponsor Thor's Hammer's Avatar
    Join Date
    May 2005
    Land of Dragons
    Age
    44
    Posts
    10,691
    Default
    Dave, thats Kgs, not lbs. X 2.2 for lbs conversion
    It was the manouverability of the thing that most impressed!
  4. #64
    California Hillbilly Sponsor CurSedVoyce's Avatar
    Join Date
    Jun 2008
    Near Yosemite in CA USA
    Age
    57
    Posts
    38,376
    Default
    Impressive machine Ed.. Thanks for posting that.
    Interesting how a limited gene pool and a limited labor force seem to be so closely related.
  5. #65
    Young man on the go Sponsor lumberjack's Avatar
    Join Date
    Mar 2005
    Mississippi
    Age
    31
    Posts
    23,329
    Default
    The Zahn has fair lift height (63" to the pin), but the lift capacity sucks massively (800lb tipping load). The Thomas has more lift capacity although slightly less lift height (best I remember on the height). Of the two, I'd take the Thomas. Its front end is light enough to keep the turf damage to a minimum.
    The Boxer 427W has an extra 7" over the Zahn and has an 1800lb tip capacity.
    The Zahn does have a swift ground speed at 5.9mph in high range, but its light weight (1300lbs+ 375 for the loader "attachment") means it's going to suck hairy ones for pulling loads. Remember you can't steer an articulated unit when it's on its front axle.
    Strength, weight, or compactness. Pick two, no loader can break the laws of physics.
    Carl Rutherford
  6. #66
    Tree Hugger Sponsor brendonv's Avatar
    Join Date
    Mar 2005
    Oxford, Connecticut
    Age
    32
    Posts
    7,641
    Default
    What is the lift capacity of the Thomas, with operator and no counter weights? (before it tips)
    trees live a secret life only revealed to those that climb them -unknown
  7. #67
    Join Date
    Mar 2005
    Mississippi
    Age
    31
    Posts
    23,329
    Default
    950lb tip capacity. 68" to the bucket pin.
    Carl Rutherford
  8. #68
    Join Date
    Mar 2005
    Oxford, Connecticut
    Age
    32
    Posts
    7,641
    Default
    950-Grapple ( 200 ) + 250 counter weight= 1,000 Really, wow
  9. #69
    Join Date
    Mar 2005
    Mississippi
    Age
    31
    Posts
    23,329
    Default
    That's a bit over simplified. Distances from the front tire matter significantly, 6-700 lbs on firm level or up hill terrain is about it.
    Carl Rutherford
  10. #70
    Woods walker Sponsor Burnham's Avatar
    Join Date
    Mar 2005
    Western Oregon
    Age
    63
    Posts
    16,317
    Default
    Wow, re the Norcar...really wow.
    "Confidence is the feeling you sometimes have before you fully understand the situation."
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
